Export Floor Colors to Color Scheme Dialog box
    Hello,
    Created a relationship diagram and liked the colors for many rooms.
    Anyone know how to transfer those colors to a room color scheme? Otherwise a bunch of RGB copy/pasting..
    Is there a function for colors used in the project?
    Thank you,
    Trevor Pan
    http://www.trevorpan.com
    Unfortunately there isn't a very easy method to transfer colors between schemes. If the parameter and the type of scheme is based off of is the same duplicate might work. Otherwise you can select "add" to replace the first color in the custom colors box. To adjust any of the others you must select the box first and then manually add your color - may or may not be faster than writing them down and reinputing them. You could also transfer one color at a time using the add method.
    Julie Kidder
    Architect + BIM Director
      jmk,
      Yea, I thought that was the case. Ended up writing them down. The trouble with so many colors is you can easily forget which one is which on the recent colors!
      That'd be a great macro to write, or some other plugin.
      Thank you much,
      Trevor Pan
