Existing Foundation Wall Clean-up
    OK, so this is a very simple model. I have existing foundation walls and new foundation walls. ALL of the walls have exactly the same top and bottom conditions (levels). Existing foundation walls are half-tone (phasing). For some reason at this intersection, they will not clean-up. They will cross each other properly, but when I try to clean them up into a corner...this happens. There are no other objects in the model above or below this intersection. Any ideas?
Name:	Exist FND walls.jpg
    Figured it out...argh! There was an existing wall above the foundation wall that was encroaching into the top portion of the level of the foundation wall. I HATE it when other people in the office hide objects for no apparent reason instead of using the temporary hide/isolate function!
