Revit OpEd: Conduit Kick
    I got a question via a tweet the other day.
    Q: "Is it possible to model a parallel kick conduit run in Revit"
    The tweet on its own wasn't enough for me but I also saw the same question at AUGI. Same person or not I find that this sort of thing happens often enough, similar questions percolate up into the internets. The description "kick" was what lost me as I haven't heard that term used before. I've mangled plenty of conduit in my past but apparently didn't get out enough for that.
    The description offered up at AUGI helped me get a sense of it though.
    It read:
    ...snip
    I have a run of (3)3" and (4)1" conduits parallel to each other. They go up the wall, parallel to the wall, then transition to going across the the ceiling. BUT this is where it gets tricky. If you are looking at the wall, facing the conduits. When the conduits get to the ceiling rather than bending towards you, they actually bend to the right and end up parallel to the ceiling. So each conduit is going to have multiple bends to make this work.
    ...snip
    The responses varied from, "too hard to bother", "why worry about that level of detail", "sure, here's a video" and a couple from me taking advantage of the 2012 "Ignore slope to connect" option. The original post was asking about 2011 and the responses that suggested that it was too hard or not worth doing are closer to the truth perhaps for pre-2012 versions. It is definitely a "labor-of-love" to pull off in 2011.
    Here's a few images depicting what I thought was being asked for.
    Here's a Video and a Video.
