Material takeoff
    Material takeoff
    Hello
    How can sum up material takeoff?
    Or what should i do to show materials for instance volume for whole project?
    Thanks!
    Actually i need help.. Would be nice to show only 1 row of material that i summed up, is it possible?
      You can calculate total per columns of the schedule, not per rows. Is that what you mean?
        My wall schedules shows every material in every wall
        50 same type insulation just different places where are they built.
        Insulation type lala: 1
        I want that schedule would show just 1 type of insulation, and total amount
        insulation type lala: 3
          Go to the Formatting tab of the schedule, select the field that you want to totalize, and then activate "Calculate totals".
            AND go to the Sorting/grouping Tab and check OFF "Itemize every instance" (lower right corner of the menu)
