Plumbing family - Fixture Units
    Someone in my company created plumbing fixture families, but they don't translate the fixture units to the piping. I added them as an instance parameter, but I still can't get them to add up along the piping. Any suggestions as to why they wouldn't?
    The plumbing fixture needs to have a connector with the "Fixture Units" type (Instead of flow).
    Then link your instance/type parameter to the fixture units in the connector.
    The piping system also needs to be set to fixture units and then it should work.
    • Fixture Units Below 1?
      When I set my fixture units to 1 the corresponding l/s is 0.189. However When I go to 0.5/0.250.001 fixture units this value remains the same? Obviously...
      March 14, 2016, 12:33 PM
    • Fixture units not reading on all items
      I have got my fixture units set for my waste/sanitary connector on my sinks, why I inspect the system the units are reading on some sink but not others...
      May 19, 2015, 09:57 AM
    • Cap Family to Generate Fixture Units
      I'm trying to create a cap family that can generate fixture units for flow tracking in our projects. My intended workflow is:
      Draw pipe to connection...
      May 16, 2018, 10:40 PM
    • Plumbing Fixture units
      Could anyone help, im trying to add waste demand units to a plumbing fixture by a shared paremeter.. but in the family the waste connector is greyed out...
      October 15, 2014, 09:55 AM
    • Calculating fixture units through T's
      Hello all,
      My firm uses Revit as a drawing software, we draw pipes in it and coordinate them but haven't used the software to it's potential;...
      April 15, 2021, 03:32 PM
