Materials on End of Walls
    Not really sure how to word it, but here's the problem:
    Take a look at the attached image. The columns are separated walls. The upper has a stud, the lower is just masonry (wrapping a structural column). How does Revit decide what material to wrap around the ends? The lower column is correct. Each material wraps the ends. The upper is wrapping the soldier course material where there should be stone. Why? How do I fix this?
    Oh, just for clarity, the brick on the side of the column to the right hasn't been changed yet. That's built a slightly different way. The side I'm pointing to doesn't have that brick below it anyway, so it shouldn't matter.
    Dan
    I figured it out. I just had to re align the edges.
    Dan
      Glad to be of assistance. Let me know if you need any more help. :thumbsup:
      -Alex Cunningham
        We now have the ability to mentally support you. Way faster than all that typing and stuff.
          Alex in my head? That's a scary thought. :bb:
          Dan
            Think of it from my perspective... I have to be in your head. Maybe you should clean up a bit... get some curtains... a touch of paint... SOMETHING!!!
            -Alex Cunningham
              Now I understand why you pushed him so hard for a good sound system...
                LMAO :thumbsup:
                -Alex Cunningham
