Does anyone have experience in creating a grille that is mounted directly onto the side of the ductwork, any suggestions or ideas on how to do this?
Flush Side Duct Mounted Grilles
I have never tried this, but since no one has replied I thought I would respond. What I would do is use an existing grill, but bring it into a facebaced family and then when you go to place it select the face of the duct you would like it on.
If there is not a facebaced family type for mechanical items, make it a faced based generic model and then switch it to the correct family type inside the family.
In Revit 2011 at least, if you use the Rectangular Tap -Beveled there is an instance parameter under dimensions called Takeoff Fixed Length. The default length is 4". You can attach your sidewall diffuser to it and then adjust this number down to say 1/2" or 1". It is not a true representation of what is going on but it allows for the diffuser cfms to propogate through the duct system. This has worked well for us.
Hi!!
I think I found an easier way to do this (?). Just learned how to do it today after pulling my hair out yesterday.
So I took an existing side wall diffuser/grille and modified its family. There was three extrusions - the first being the grille itself, the second the part that connects the grille to the duct and the third part is "the duct".
You take the third extrusion and fix the dimension of that (aka how thick the duct can be in the wall). Then you add a connector to the top of that third part.
Horray!! Now I can move foward with putting in my low wall exhaust ducts!
I came accross this when searching for a solution to a different problem and thought of you...
Could you not make a diffuser / grill family and under Family Category and Parameters set the Part Type to Breaks Into? Wouldn't the diffuser / grill connector then 'break into' the ducting directly without the need for connectors and such?
Just a thought...I could be horribly wrong...
Ciao for now.Say something interesting....
Grille Problem
Originally posted by Gabriel Black View PostI came accross this when searching for a solution to a different problem and thought of you...
Ciao for now.
I am also facing same problem with grille.
i want to place grille in duct with at least 50 mm clr but unable to place. please let me not if any solution.
Shadab
Shadab
I work for an HVAC manufacture / installation company which has recently acquired Revit MEP. As square ducting is manufactured in segments of approximately...
Channel: MEP - General
November 21, 2013, 12:27 PM -
Good morning all,
I need to build a fire damper family. Trick is it doesn't break the ductwork. It's slid into place IN the duct. If I'm...-
Channel: MEP - Family Creation
July 6, 2015, 07:01 AM -
Hi all,
I'm already quite certain that the following is in no way possible in native Revit (no plugins), however, I still want to raise the...-
November 25, 2015, 12:21 AM -
I have a 700 x 700 duct and have another duct 700 x 300 above, which i want to drop down which i would like to connect it into
i cant seem to do...-
December 4, 2014, 10:44 AM -
Can anyone help me find a revit family - rectangular duct fitting - 30x18 to 22x18 & 8 x18 these last 2 are side by side
October 28, 2013, 09:21 PM -
