Imperial and metric
    Imperial and metric
    Does anyone know why there are no wall families to load in thestandard OOTB configuration?
    If it comes to that,if you start off with an imperialtemplate , if you change the units tometric is there not an easier way to deal with walls you have inherited? i.e.walls which are listed as 8” and are listed as 202.8mm in family editor?
    The default Metric template does have walls, and in mm format.
    If you change a imperial model to metric all the names will be retained from the original, as they are just names. You will have to modify the name to reflect the change. Just create new walls with the correct sizes or transfer walls from a metric project.
      Do you know if USA are using metric or imperial ?
      Thank u
        All I do know is that it's all imperial, the metric is but a mask.
          Thank u
          We're still backwards around here. You probably won't find much metric in the US.
          We tend to think it's a lot easier to add 4'-3 5/16" + 12'-9 1/2" than it would be to add 1135mm + 3416mm
          Dave Plumb
          BWBR Architects; St Paul, MN
            I don't remember if I first saw this from someone here or somewhere else but - great explanation of the genius behind the imperial measurement system (and paper sizes!) follows:
            https://www.youtube.com/watch?v=r7x-RGfd0Yk
            https://www.youtube.com/watch?v=mHeo62B0d0E
            chad
              Thank u
              Depends on what is getting built... Most US Government projects are metric, everywhere else imperial.
                4'-3 5/16" + 12'-9 1/2" than it would be to add 1135 + 3416:
                Hmmmm.... yep, that's a smart system you have there, count the keystrokes alone over your lifetime. Great if your being paid by the stroke. I always wondered how you guy's ever got to the moon when you did with systems like that.
                Mark Balsom
                  Not sure if everyone is aware but in a metric template Revit allows imperial tabular input into active metric dimensions and temporary dimensions and auto converts leaving metric display. I use this a lot imputing old jobs from from original imperial plans. Yes we were once imperial here in OZ many moons ago until we saw the light in 1966.
                  Not sure if Revit allows this sort of input in imperial template.
                  Mark Balsom
                    Yep...you can enter 915mm and you get pretty close to 3'
