Room shading is blocking walls and doors
    After designating all my rooms and picking the colors for them I can't "send to back" the color shading to show the doors and walls. I must me missing something really simple but I can't find it anywhere.
    I am measuring rooms from the centerline of the walls.
    RAC 2012
    Thanks
    Nope, it's not you. It's your graphics card. I have the same problem, tried anything to fix it. But it doesn't help. Only upside is (for me at least): it is not an issue when printing. Pdf, to paper, both print just fine.
      Make sure view is not set to Wireframe.
      see attached.
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        LOL, that would be the normal behaviour... With me, the "wireframe"mode also happens when in hidden line (HP notebook, FireGL videocard. Not currently at hand so I don't know the precize specs). But the pc works fine.
          That works Cliff. I like easy fixes.
