Applies to: - All Verticals, and especially when in the Family Editor.
New Feature / Problem:
Detail lines with the option to COMPLETELY disable all the constraints that detail lines currently keep making automatically. Also fix the grouped detail line work slowdown.
Detail Line slowdown is rampant in any project that puts detail lines into heavy use. Waiting 5 minutes for a tiny Cad block to update is unnerving and infuriating.
Workflow:
Draw detail lines and then grab them, in your detail line options you will now see a check mark allowing you to disable all associations the lines will attempt to make to other objects. You now have dumb detail lines! FINALLY!
Benefits:
Massive benefits in performance when using detail lines a lot.
Attachment comments:
Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
Workflow:
Benefits:
