model a sphere?
    model a sphere?
    how do i model a sphere?
    a 360 revolve with a circle?
    Yep.
    Can be done as a Family, or a Conceptual Mass--depending on what you are using it for.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      I want to make a ball that I can put in some millwork to see if I have enough room to hold 30 balls. I think I got it as a family, however they are difficult to move.
        Wouldn't it be easier to find that out using paper, pencil, and calculator?, or a formula in the millwork family?
          Perhaps you could post an example?
          Cliff B. Collins
            eh, check these bad boys out!!!!!!!!!!
            they nest so nicely!!!!
              Well, it seems that you had an answer to the question already.
              Another alternative is: Massing > In place mass > Component > Load family > "sphere.rfa" > place on work plane
                yeah, i sort of figured it out as i went...good to know alternative ways to do it!
