Can the arrows in dimensions be changed, fo example can the 'Open Circle 3mm' be changed to 2mm, etc. ? Thanks in advance, Kamran
Arrow Size Change for Dimensions ?
Yup, go to Manage > Additional Settings > Arrowheads. Select the Type you want, create a new type and change the Tick Size to the desired size.Martijn de Riet
Hi, i need to change the letter size of a viewport, help please.March 27, 2019, 02:04 PM
Hi, i wonder how i can change the size of dimension tickmark so it become convenient with surrounding drawing (Image attached)...May 14, 2012, 04:10 PM
Hi, Is there a way to change the size of components I've downloaded?
October 21, 2016, 09:26 AM -
I am trying to best figure out how to dimension a floor plan that suits my needs and in doing so came across a question. If you were to use the Dimension...October 7, 2015, 04:18 PM
How to change a Arrowhead style of Temporary Dimension Style ?August 1, 2011, 07:55 AM
