Revit OpEd: Revit MEP - Silly Revit - We Don't use those Pipe or Duct Sizes
    If you don't take the time to fine tune your project templates then you'll find Revit will offer you all kinds of pipe and duct sizes. These are available in the drop down lists during placement and then later if you run Duct/Pipe Sizing.
    If you don't take the time to fine tune your template you'll find Revit gives you a duct size of 11" after completing its Duct Sizing, regardless of the fact you only choose from even sizes. It's easy to blame silly Revit...but it's our fault. The Duct and Pipe Sizes are controlled via Mechanical Settings, the duct sizes for Rectangular are shown below.
    We need to either delete sizes we never want or just un-check them in either column or both, Set it and forget it.
    Oh, the same is true of conduit and cable tray.
  • Duct accessories not resizing...
    This is probably a well known source of frustration and a search didnt come up with any solutions so there probably isnt one..... but i will ask the revit...
    July 26, 2013, 12:52 PM
  • change duct/pipe size
    hello
    i have a small duct to modify, the diameter has to increase because flow increases.
    i asked to some of my colleagues who told that i...
    April 28, 2017, 01:57 PM
  • Duct Grill on side of pipe
    Im wonder if ist possible to placed Duct Grill on side of duct. Im not sure if ist depend of Family or on Pipe Routing
    June 21, 2016, 02:31 PM
  • Revit Duct sizing issue
    Dear Friends,
    at revit i am tring to size duct with "Duct/Pipe sizing" function. Problem is it sizes some duct like 150x200. However i...
    April 3, 2015, 05:27 AM
  • Takeoff position
    How do I control duct takeoff position?
    Sometimes it takes off from side of the duct, while other times it takes off from top or bottom -...
    January 11, 2019, 10:26 PM
