Assign standard keynote to custom detail comp
    Im sure this is simple, but I cannot find it.. All I want to do, is to create some standard custom detail components, like a strip of vertical timber boarding. I can create the family, no problem, but I cannot find a way of hard coding in the keynote that this particular family would use. I would want to do this, so that people dont get the opportunity to select the incorrect keynote, using user defined..
    Cheers in advance...
    Andy
    I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it
    The Keynote parameter is under "Identity data" in the Family Types window, in the Detail component template. Just put a value there, and that will be the "hardcoded" keynote value of your detail component in the projects.
      Hey Alfredo,
      I hope not many people have read my question as I cant believe I didnt see that.. :banghead:
      Thanks for pointing it out for thou..
      As always, many thanks...
      Andy
