Is there any possibility to see the grid lines in 3D view?
Grids in 3D
No. Grid lines are visible in orthographic views only.
A workaround would be to create some model lines in those views by picking grid lines. Then, you will see the model lines in 3D.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by lucis29 View PostIs there any possibility to see the grid lines in 3D view?
This is my first attempt at attaching a file, hopefully it worked. This is a revit family that has been around a while, not sure who created it, but it shows the grid number/letter in the line itself for easy reference and can be raised to a new offset level so that it's easier to see in a 3D walk-thru. We mainly use this for viewing in Navisworks, works great.
I must search a little, but navisworks's guys found a way and made a family to deal with this. It was a while before A.C.I.N.O.F (AUGI CRASH IT's NOT OUR FAULT) :-))
see you soon....
3 min too late......Julien
P. DAC
Originally posted by lucis29 View PostThank you, jhenry. I used it, its very good. Is there anyway I can flip the text? Is written upside-down.
http://bimmanager.blogspot.com/2007/...avisworks.html
This method used for Navisworks should work for Revit as well...
Originally posted by gdoherty0102 View Posthttp://bimmanager.blogspot.com/2007/...avisworks.html
This method used for Navisworks should work for Revit as well...Martijn de Riet
Can someone explain why the vertical (1-6) grid lines i view in level1 and level2 is NOT present in levels3, 4, 5 and 6? I wonder just the vertical (1-6)...June 29, 2011, 05:47 AM
I need to show the grid lines in my 3D ISO view. How can I do something like this. It dosen't need to be atcual grid lines, but they need to look like...January 5, 2012, 05:58 PM
I have change the color of grid and level lines to a shade of gray in order to be less intrusive on the drawing, but in the process realized that lines...November 10, 2016, 02:18 PM
Regarding grid line 2d and 3d options,...a great addition to Revit would be a utility that could select all grid lines in a view and give you the option...November 15, 2014, 12:30 AM
I made the mistake of moving my grid lines in 2D to their desired locations on one of my floor plans, and now I cannot select to move them in 3D, and...October 18, 2019, 09:48 PM
