I am using Revit MEP and trying to place room tags into a building that is a xref of Revit architecture. As I am about to place the tags, I noticed that it reads the original room names from the Revit Architecture file. But when I click to place the room tag an error pops up saying that the tag is not visible in the current view (which is a floor plan so it should). I tried ajdust my visibility/graphics, the view range, and my worksets are all set up as they should be. I tried utilizing the space naming utility but this was unsuccessful becuase the spaces would load but, again, there were no room tags. Does anyone know anywhere in the program where my views or visiblity might not be set up right, or know the sollution to this problem???
Invisible room tags (Revit MEP)
Originally posted by Justin8304 View PostI am using Revit MEP and trying to place room tags into a building that is a xref of Revit architecture. As I am about to place the tags, I noticed that it reads the original room names from the Revit Architecture file. But when I click to place the room tag an error pops up saying that the tag is not visible in the current view (which is a floor plan so it should). I tried ajdust my visibility/graphics, the view range, and my worksets are all set up as they should be. I tried utilizing the space naming utility but this was unsuccessful becuase the spaces would load but, again, there were no room tags. Does anyone know anywhere in the program where my views or visiblity might not be set up right, or know the sollution to this problem???
Keep in mind:
Your cut plane has to go through the space in order for the tag to be visible.
Room bounding checked
Space tags visible in VG"Keeping my view range hopeful"
I am facing the same kind of problem. I linked architectural model in Revit MEP and my all settings are proper for visibilty/graphics for space and space tags. The issue is that when I am using Space Naming Utility or tagging space using Space Tag it's not detecting room names and number. Morover when I select the space, the room numbers and room names are not showing up even in properties which they supposed to be. I checked Architectural Model and I found that rooms are in another design option but that design option is set as primary option. I also tried to keep that design option as current design option in Revit Linked file from Visilility/Graphics, but it also didn't work. So any suggestion????
I had a similar problem a couple of days ago. It took me hours to realize what I'd done wrong:
I was making insulated rooms and labeling them with my newly made, hot, shiny room lables when there was this one room that was really giving me grief. It'd tell me there was a lable already assigned to it. I'd float over it and sure enough, it was there. I'd delete it, re-do it, re-name it and STILL it wouldn't show! It was there, but invisable!
It took a long time for me to realize that I'd placed a ceiling in the room - just like the others - except this ceiling was lying on the floor! Of course I'm not going to see a room lable on the ground if there's a ceiling lying on top of it! I put the ceiling on the correct level and BINGO! Room lable visable.
I'm such a pleasant idiot...Say something interesting....
Originally posted by CHintan.thakkar View PostDesign options are set on architectural model not MEP file. And all room annotation are on in MEP file as well as linked architectural model still it's not showing up."Keeping my view range hopeful"
Has anyone actually solved this issue? A coworker and I are going through the same deal.. with no luck. Everything we know to check seems correct, and on multiple projects prior have never had an issue with using room tags. Now, both plumbing and electrical plans have this issue but HVAC plans seem fine. Is there something possibly in the view template that's not under "Annotation" or "model" v/g overrides?
We are using Revit MEP 2016 with a linked Architectural model from an outside source.
I have an architect's model linked into my MEP project and have it checked as room bounding.
I want to use their room names...June 16, 2016, 08:58 AM -
Project has two levels. Level 1 Space tags reflect the Architectural Room link information just fine; Room Number, Name and sq ft. Level 2 Space tags...
Channel: MEP - General
December 7, 2012, 07:48 PM -
Hi all. I'm not sure what the issue is, but my Space Naming utility is not working. It will not update the names and numbers of my spaces at all. The...
July 17, 2019, 09:20 PM -
Why wont my room tags from my linked architectural model stick???
If i hover over the room the name of the room will appear but as soon as...-
October 19, 2015, 03:16 PM -
In our architectural model, we need to renumber our rooms based on a client request. Our mechanical engineer (who is using Revit MEP 2012) is concerned...
July 2, 2012, 02:13 PM -
