Should i create separate roofs for those parts where are ventilation ducts as well where is 2% ?
I love roofs
"I love roofs" OK you got my attention.
At 2% or 2° ? the valley would be very flat, not good. You could use two different pitches.
Either way see attached project on how to go about it.
This is a handy trick using a negative pitch as opposed to slope arrows (both work but handy to know both) and same process is used for doing as they call in the US "crickets"Last edited by mark b; July 21, 2011, 01:54 AM.Mark Balsom
I have two hips from different roofs that come together in a flat valley. How do you go about making an overbuild on one or both of the roofs to solve...February 2, 2016, 04:47 PM
Below is the support request I submitted to Autodesk regarding roofs and the new parts functionality...
There are some...August 4, 2011, 09:32 PM -
Hi, I'm new to this forum . . .couldn't find an answer to this anywhere on here so I'm hoping someone can help. I do residential design and I currently...September 11, 2012, 09:38 PM
Tried several options to design this type of roof within Revit, but since I'm still a n00b working with masses, I might need some help. The attachment...December 5, 2012, 08:05 AM
Hi
I'm trying to make a roof by footprint on curved and straight walls and the following error always comes up: "Can't make footprint...January 11, 2017, 01:48 PM
