External Surface Area - Wall to Floor Ratio
    The top floor of my Mass Floor Schedule is counting the roof surface as External Surface Area. I need it to just count the wall, like the other mass floors.
    With simple forms I've just increased the height slightly, to include the parapet height for example, and then given the new mass floor a parameter value I can filter out. However for stepped forms, the lower mass still produces excessive External Surface Area Values by including its roof surface.
    If your looking to get the wall area - paint your wall faces with a distinct material - then schedule that material. Or if there is more unique walls than roofs do the inverse for roof surfaces
