Revit won´t allow us to draw line pieces shorter than 0.8 mm´s (1/32")
Normally that´s not really an issue, but occasionally I´ve had the need for some 1:1 details, and for creating titleblock logo´s.
Note - The following trick only works for families (not in the project environment), and is fairly simple.
Draw the detail or logo at a larger scale i.e. 100:1 (0.5 mm´s become 50 mm´s) and when finished, just select all the linework, and scale it down to fit. Voila, Revit now accepts those short lines.
