Is there a way to extend top rail only flush with the end posts (to the ref plaines on elev. view)? Thx.
Railing
You have to change the offset of the ballusters....bummer part is you have to have to create two different types of ballusters to make this work as offset is left and right and not start to finish....so you would have to change the location of the balluster in regards to the origin.
If you really need to show it extend out, model it as a family or just use a masking region in elevations....
Okay....ignore what I just said....Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by dzatto View PostOkay, wrong one. Look under balasters placement. Posts section (at the bottom). Start post and end post space.. I'm ending up with those funny looking rail ends (pic.- rail 1). I don't think any of those options/adjustments will work for me. I was hoping for some kind of trick or work-around to make this happen.
Originally posted by MPwuzhere View Post...have to create two different types of balusters to make this work...
I need to extend the toe plate on a railing system. I'm not seeing an option to execute this in the railing editor or top rail properties. I'm thinking...March 26, 2021, 04:44 PM
Hi all
I am trying to figure out the spacing between balusters on a deck railing. If I leave the "Post Space" option set to 0"...December 14, 2011, 04:03 AM -
I'm looking for some direction on how to create a railing that has 1-1/2" square balusters every 4-6 feet and wire cable rail (vertically oriented)...September 5, 2017, 07:10 PM
Hi, i'm in 2013. I'm modelling a railing which is 1100mm high along the flight and 900mm from the landing. So I've set the Landing Height Adjustment parameter...April 28, 2014, 01:26 PM
Hello, I'm creating a railing with a round handrail and rectangular profiles as balausters. The balausters have a semicircular cutoff that's intended...November 10, 2011, 05:03 PM
Monumetric Footer In-screen
