Strange Print issue
    Strange Print issue
    If i choose to select a set of sheets from a project and send to a printer, occasionally one plan will be printed more than one time. i.e sheet A1.01, sheet A1.02, A1.03 are all selected and sheet A1.02 will be printed x2. it does not matter the printer it is sent to and it does not always happen. I was wondering if anyone else has had this happen or knows why it is happening.
    Thanks
    Thanks
    that happens here occasionally from three different printers. I've never figured out why it happens and it's intermittent. PITA to have to check all printed sets for dups though
    Edit: oh, and welcome to the forum!
      This happens to me also, when I have a sheet open (I had been working on it) If you close all open views before you print, the duplicate sheet does not print
