I've been instructed to convert a project that I did in Revit earlier this year to AutoCAD format for archival purposes. I've had the opportunity to convert a view here and there to .dwg but have never had the experience of doing a whole project. The project was done in Revit 2011 and I see that there is an export option to .dwg when in a sheet view that allows all of the sheets to be exported to .dwg. Is this the right way to accomplish this task. As there are over 400 sheets to convert I hesitate to just press the button not knowing what I'm getting into. Advise?
Convert Revit to CAD?
Well, yes, that would be the right way. Remember though to check off "xref views on sheet". (btw: this is in the "save as" screen where you specify the name and save location). That will export all views on a sheet separately and then xref them back in the "sheet dwg".
EDIT: not quick enough...Last edited by mdradvies; July 19, 2011, 12:25 AM.Martijn de Riet
Originally posted by renogreen View PostAs long as you un-check the box that says export views and links as xrefs it should be ok, if it's just for archive purposes. If you let Revit set those views and links as Xrefs you will have an enormous mess on your hands.
Originally posted by mdradvies View PostWell, yes, that would be the right way. Remember though to check off "xref views on sheet". (btw: this is in the "save as" screen where you specify the name and save location). That will export all views on a sheet separately and then xref them back in the "sheet dwg".
EDIT: not quick enough...Thanks to you both for the help! I'm going to push the button on my way out the office tonight and see what it looks like in the morning.
I began replying to Gordon's post about PDF's + DWG's, but didn't want to take over the thread...
I WISH revit could import (scaled) pdf's...April 14, 2011, 10:18 AM -
Hey all
Currently finding an issue when exporting my sheets to .dwg
I have a 30+ storey tower and am using linked models for...March 14, 2013, 02:49 AM -
Hello,
simple question and so far not found an answer for it:
if you export a plan view to cad, using shared coordinates, the...May 12, 2017, 11:03 PM -
I can't export to DWG only for a particular sheet... Revit crashes and only creates a tiny 13 Ko blank DWG file.
I've tried...-
December 19, 2011, 05:08 PM -
Hi all,
Im having trouble exporting sheets as dwg. The layout views appear empty in the export dwg file. In the model space, the views are...August 23, 2017, 11:12 AM
