Importing from sketchup and rendering
    When I import a 3D object into Revit, such as a yellow tower crane, when I render it, it appears white/greyish (sort of monochrome). How can I get the colours to render as they appear originally?
    I'm very new to all this revit and trying to teach myself is very hard so I would appreciate some help.
    Thank you!
    Load the SU file into a Revit family. Save, then laod into your Project.
    In the Project, go to VG ( visibility graphics ) and under Imported Categories, go to Object Styles. Then set the material for the different SU entities.
    It should now render properly.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
