Hello everyone.
I need to get Image, DWFX and FBX files of selected family element in project. I am trying to do this with following code:
So. I want to open Family Document using API function Document.EditFamily and then export it to other formats. But when I export famDoc to Image I get image of currentDocument not famDoc. When I export famDoc to FBX and DWFX the Export function always returns false.
Anybody knows how to get Family Image and Export to FBX via Revit API without opening and activate Family Document or it's not impossible?
Thanks.
Code:
Element el = commandData.Application.ActiveUIDocument.Selection.Elements[0]; if (el is FamilyInstance) { Document currentDoc = commandData.Application.ActiveUIDocument.Document; Family fam = el.Symbol.Family; //Get family document Document famDoc = currentDoc.EditFamily(fam); //And now I'm trying to get Image ImageExportOptions ieo = new ImageExportOptions(); ///.... ///ieo.Init famDoc.ExportImage(ieo); //get exported views ViewSet vs = new ViewSet(); //In this case Active View always null if (famDoc.ActiveView == null) { FilteredElementCollector collector = new FilteredElementCollector(famDoc); // May be you know how to get default 3D view with other method var views = collector.OfClass(typeof(View3D)) .Where(v=>v.Name == "{3D}") .ToList(); foreach (View3D v3d in views) { vs.Insert(v3d); } } //And Export to FBX //Here export always false if (document.Export(Path.GetTempPath(), tempFile, vs, new FBXExportOptions()) == false) { } //Export to DWFX //code same as export to FBX }
Thanks.
