Extensible Storage
    Extensible Storage
    Has anyone used this? Is it slow to sore data on an entity?
    I am storing text data and it is not instant it takes around 5sec to commit. Is this normal?
    Code:
            public static void SetData(Element element, string fieldName, string value, Guid guid)
                var trans = new Transaction(Document, "n8_CreateAndStore");
                trans.Start();
                var schemaBuilder = new SchemaBuilder(guid);
                schemaBuilder.SetReadAccessLevel(AccessLevel.Public);
                schemaBuilder.SetWriteAccessLevel(AccessLevel.Vendor);
                schemaBuilder.SetVendorId("N83D");
                FieldBuilder fieldBuilder = schemaBuilder.AddSimpleField(fieldName, typeof(string));
                fieldBuilder.SetDocumentation("A stored string value " + fieldName);
                schemaBuilder.SetSchemaName(fieldName);
                var schema = schemaBuilder.Finish();
                var entity = new Entity(schema);
                var field = schema.GetField(fieldName);
                entity.Set(field, value);
                element.SetEntity(entity);
                trans.Commit();
    luckily retrieving the data is quick...
    Code:
       public static string GetData(Element element, string fieldName, Guid guid)
                Schema schema = Schema.Lookup(guid);
                Entity retrievedEntity;
                if (schema != null)
                    retrievedEntity = element.GetEntity(schema);
                    if (retrievedEntity.Schema != null)
                        return retrievedEntity.Get<string>(schema.GetField(fieldName));
                return "";
    Sorry, could you elaborate? What are you trying to do here? It doesn't seem to do anything with me... Do I need a 3D geometry here?
      Unfortunatelky there is a Pause. During Alpha/Beta testing I bought it up as, as you say I was noticing an approx 5 sec delay. I have since used ExS on the RTM version of Revit and it did seem better. Certinally not a 5 sec delay.
      Phillip Miller
      Kiwi Codes Solutions Ltd
      Makers of "Family Browser" and "Project Browser" for Revit.
        Lets hope the next version has a 4-5sec improvment.. Cheers.
