New Revitor
    New Revitor
    i 'm a new user for the revit, i had download revit structure 2012 from the auto desk the trial version
    i have some questions ...
    1- what is the difference between revit structure and the revit structure suite ?
    2- there is no materials in the version i download it! there is no columns example nor foundation or any, when i say put a cloumn a pop up window cames up saying if i want to load one :S
    The suite will include Autocad Structural detailing.
    When you installed Revit it should have prompted you to install the library as well. Run the install again and check if you can install the library again.
    Generally for things like columns you load what you need when you need it, which is where the library comes into the picture
    Revit BLOGGAGE
    http://www.revic.org.au
      Hi Renoz,
      I will answer the first question:
      Revit Structure Suite contains Revit Structure + Autodesk Structural Detailing.
      Revit Architecture 2013 Certified Professional
        i guss i did that?!, anyway i 'll try it again with the library.
        and about the suite it sounds better than the normal revit?, you think i better use the suite?
          You can install ASD and use as vanilla Autocad as well. No need to install acad then
          Revit BLOGGAGE
            If you already own AutoCAD it's also cheaper to upgrade to a suite.
            Cheers,
            Jasper
            EversPartners
              It depends what you want to do...For Europe, Revit is not very friendly with reinforcement plans. Also, imho, ASD steel is (a lot) better then Revit for steel detailing.
              Here, in Romania, I use Revit only for formwork plans, (some) quantities and to impress the client with the 3D model.
              Regards,
              Lucian.
