visibility beam
    visibility beam
    If i draw a beam in plan view en define the height, the beam disepare. Is there a posibility that the beam is in place and you can see a dash dot line and two dashed lines in plan view?
    thx
    Hi and welcome here.
    you will have to learn how to play with view range settings. online help(F1 key) may help you with that. direct link
    another thing you can do is set the view from the level above as an underlay (see in the properties of the current view).
    good luck
    Julien
    P. DAC
      This was posted yesterday on RevitKid and is good explaination of view range.
      Mark Balsom
