Why am I getting this condition on my hipped roof?
    Any idea why my hipped roof won't ridge to the corner? TIA
    Make sure the ‘offset from roof base’ is the same for all sketch lines.
      Yeah they all have 0. There is a different overhang value though. Maybe I need to make two seperate roofs? Thanks for looking.
        You can do it in one roof. Edit the roof footprint, then select "Align Eaves," choose "Adjust height," select an eave with the correct height, then the offending eave line, then finish roof.
        See http://autode.sk/1W4NmiH
          Have you used pick walls with overhang option when you sketched your roof? Redraw using line or pick lines with an offset.
            Chris, that did the trick. Thanks so much. I look forward to the day when I can give back to this community. Nice work!
            Thanks PijPiwo too...
