Anomalies when placing a panel onto a surfacce
    Hi all,
    Can anyone tell me how to fix this problem (see attached pic). I created a surface, applied to pattern to it, then created a family panel for that pattern, but when I load it in it has these bits that overhang. I know I have seen a tutorial about this in the past but I can find it again. Any suggestions?
    Thanks
    Lox
    Quick fix>
    Make ON/OFF parameter in your panel family and just turn them off...
    Easy things are not worth the effort
    http://www.teamcad.rs/
      actually, all edge conditions should not be handled by revit, you should make a 3 point adaptive component panel and stitch it on.
