Hi!
I am writing from Finland. We have here metric system.
I want to create a structure where is only 1 millimeter wide steel cover. For example 1 mm steel cover - 150 mm isolating layer and core - 1 mm steel cover. Now the revit only allows me to insert 1.6 mm not 1.0 mm. Why is that? By the way 1.5 mm is also not enough?
Thank you!
Thank you!
