Dimensions, Font Size
    I am trying to best figure out how to dimension a floor plan that suits my needs and in doing so came across a question. If you were to use the Dimension tool and you selected many multiple wall and had many multiple dimensions what if one of those dimensions is in a tight space, How could you shrink just that one to fit in the given space? / Is there a way on a dimension line to change the font size on just one of those dimensions even tho when you hover over it it is listed as one "bim object"?
    You can't change the font size, but you can grab the Dimension String and move out out to a readable position.
    Revit will automatically add a leader that points back to the Dimension Line.
    Dave Plumb
    BWBR Architects; St Paul, MN
      Okay, I see. One of my work arounds that I've been working on today would be to have all single instances of all interior dimensions that way I can have say in the size of each particular dimension. Very similar to how AutoCad works so I can deal with it. Although I would prefer that there just be an option to make one smaller as was being asked earlier.
