How to create Radial array with radius as a parameter
    I need to create a parametric Radial array with radius as a parameter in Revit MEP 2009
    I am able to create the Radial array with any number of components.
    But I am unable to control the radius of the array.
    Please provide a solution to make the radial array with both number of components and Radius of the array
    Thanks and Regards,
    N Thangamariappan
    You mean like this ? if so select the radius dimension that is associated with your radial array and give it a parameter, Radius or what ever you want to call it.
    Mark Balsom
      It works fine
      Thank you
