Draw order- select multiple elements
This topic is closed.
    Does anyone know of a workaround to using the draw order command to select multiple elements at the same time. If not, does anyone know if Autodesk is considering implementing this feature in the next release or why it is not readily available?
    Juan Carlos Moreno
    Sisley Cosmetics
    Sounds like an App to me. (Revit API)
      What do you want to do? Filters on selections can work,no?
      Julien
      P. DAC
        Sometimes I'm drafting something and I need to grab, say 2 or 3 drafting components or masked/filled regions, and bring them to front. But I have to do it element by element. This is fine but when there are a lot more elements there are a lot more clicks. I was wondering if there was a way around this so that one could select any number of detail components and bring them all to front or send them to back using just a couple of clicks
        Juan Carlos Moreno
        Sisley Cosmetics
          I would say: select all instances in view; or filter on a selection.
          Next thing: record a selection, only in Revit Structure.
          Julien
          P. DAC
            There was an API flaoting round that did this, but I don't know where it is or even if it is still current.
            But that's the only way to currently acheive this.
              is this actually available in RST??? it is sorely missing from RAC...
                Where do I will get this option in RST??
                Yogesh
                  Under the modify tab it should appear. It's a special sort of filter that relies on selections rather then rule based systems.
                    I checkd with modify tab...it is not there...
                    Yogesh
