Well, Override graphics in view, set all categories to thick linestyle. Revit prints everything in Thick Linestyle, but you won't notice that when you have all Object Styles set to a thin style.
I was hoping for some kind of function like " print all lines in thin lines". So i have to make manually in Override graphics in view, then in object styles.
When i change in object styles, is there any DEFAULT function, or save settings as? because if i set line weight to 1, hit save. Previous settings will disappear.
Why? What effect are you trying to get that you have no lineweight differentiation? Perhaps there's a better solution than just overriding all the lineweights...
if I want to change the display, say, of the cut lines of a mass in ALL my views, is there a way to do this without resorrting to a graphic template,...
I am finding lately that everytime I open a family the reference plane object style comes up as solid lines even in families where it previously was dashed....
