I am brand new to artificial lights. I have an exterior light that WORKS when I render- but I wanted to try a different one. So I simply loaded the wall light that comes with Revit 2011. Still has the same sun and artificial lights for render and all I did was put this light on the wall and set the watts to 10,000 just to see if it would light up- but it doesn't.. It is listed and checked as "on" under light groups for render. See the image of the instance and edit properties of this light and please tell me what I need to do to make it work. Thanks
Exterior wall lamp
Hi everyone , i am facing problem when choosing sunlight and artificial light theme, the spot light is not showing although i am on the time of evening...
Channel: Rendering and Gallery
November 19, 2011, 09:06 PM -
Ok I have created a bunch of light fixture families and for some reason this particular family isn't rendering any light source. I would love any suggestions...
February 4, 2015, 04:15 PM -
I'm unsure how to get light into a room when rendering it's almost pitch black when I try at the moment. I've attached a picture to show you what I mean....April 14, 2014, 01:42 PM
I need some help with my lights for a render. I'm new to rendering and have only ever played around with it once before.
I'm trying to create...January 13, 2014, 09:23 PM -
Hi all, I rendered this house and it looks great, the only problem is, the front door is recessed in and it can't be seen, too dark in the porch. I have...June 21, 2011, 05:37 AM
