Family With Multiple Parameters ( excel style format)
    Hey Everybody,
    I wanted to know how do I make a family, lets say of a Window, in which the parameters such as height, width, finish, type of glazing, etc. is driven by a table (like the one that comes up when you load beams or columns
    Thanks in advance!
    Juan Carlos Moreno
    Sisley Cosmetics
    Originally posted by JCM View Post
    Hey Everybody,
    Thanks in advance!
    it's called a Type catalog. See here: http://revit.autodesk.com/pillar/cus...e_Catalogs.htm
      You need to create a .txt file with the same name as the family, and save that file in the same folder. That file will be the catalog. To learn about creating catalogs, please find a document called The Families Guide from www.autodesk.com , or open one of the existing catalog files already included in your libraries, to find out how they work. There are several of them in the Structural/Framing/Steel/ folder.
        Thank you very much!
        Juan Carlos Moreno
        Sisley Cosmetics
