To Room Field is Completely Blank in Door Schedule
    Hi All:
    I had some coiling doors as a placeholder in a project that were scheduling correctly, and then I replaced them with the 4XX_Sectional_Overhead_Door family from Overhead Door Company, which can be found on their website here: BIM Objects / Families , using type 424_Full Glazing. I did do some work altering the door tracks for a vertical lift, but that's about it.
    Now the field for "To Room" on my door schedule is completely blank. I have tried to click on the drop down arrow and there is nothing there.
    Any thoughts as to what is breaking this?
    Thanks!
    Debby
    Maybe the door is showing the room in the other parameter, the "From Room".
      GAH! I added that to my schedule as a test - and it worked on one room. And it turns out that that room had the limit offset at 20', rather than 10'. So I changed them all to 20'...and now they appear. Holy cow. Such a simple thing.
      I appreciate your help, Alfredo! Thank you as always.
