Hello everyone,
I've been trying to search for some solution, but nothing about this that I could find. I'm now working on framing plans - roof, floors etc. I got the roof all set. Added log rafters using the beam system and picked the bottom of the roof plane. After I finish the boundary and go back to section I noticed that there's a gap between the bottom of the roof and the top of the log rafters anywhere from 1" - 2". Why is it doing that?
My work around is to make a ref line and set it to the ref line and move it up to flush with the roof, but if I move the roof up or down, the ref line won't move with the roof. It's also doing that for the floor framing as well that I need to use the "elevation" in the properties to move it up or down.
Or should I just drop the beam system and just array them instead? What's your preferred method?
Any help would be great!
Cheers!
Cheers!
