Steelwork on sloping soffit
    I have a roof supported by steelwork, I have set my work plane to the slope and drawn the beam in however how do I set out the beams in plan view?
    I have drawn 2 reference planes in plan, I can snap to the horizontal line but cannot snap to the angled line how can I do this?
    Revit 2019 user
    Do you need to schedule steel framing as structural steel? If not, use Sloped Glazing roof.
      In a Section or Elevation, Create a Reference Plane parallel to the slope. Name it Roof Framing--or something like that.
      Then, Set the Ref. Plane as current.
      In a plan view, create a new Structural Beam System. ( it will need "supports" such as walls or columns, usually at the four corners of a rectangular bay. )
      Assign a steel framing member ( joist ) to the beam system. Give it a spacing. That should work. You may need to adjust the height of the Reference Plane/beam system to your roof.
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        Are you designing / calculating the steel work? should that be leading this rather than matching the steel to the underside of the roof? How is the steel going to be fabricated/connected/supported. These things should be taken into account now, otherwise you will just be re-modeling this once the actual design is completed.
          I have picked the slope in 3D view to get my reference plane is there anyway to name this reference plane? or draw in this reference plane in plan view?
          Revit 2019 user
            Yes--highlight it, and in Properties, give it a name.
            You can't draw a sloping ref. plane in a plan view--draw it in section or elevation view.
            Cliff B. Collins
              Cliff what I meant was if you use the pick a plane option is there any way to name this reference plane?Click image for larger version
              Revit 2019 user
                You give it a name (in Properties) first, then select it in the dialog box. You can't name it from the dialog box.
                Cliff B. Collins
