Missing wall base
    Missing wall base
    So we made some nice looking wall base in our 2011 file and then when we upgraded the file to 2012 the base has disappeared/is now in the center of the wall, not the face. Anyone else run in to this problem? Fixes?
    Could you post an example?
      My guess is if you open the profile, modify it and reload it, it will fix it.
        That's what I thought originally, thinking maybe that the family was still a 2011 and needed to be updated to 2012. Didn't work.
        I'm trying to put the base on the wall on the left window, you can see it in the wall on the right window.
          This is not an answer, but we also had some similar things that started happening to a project in the move from 2011 to 2012.
          I was using the some wall sections as bases and wainscot and so on, and after 2012 some of these start snapping and cleaning up very oddly with the walls that the are running parallel to. The walls seem to be 'stickier' in 2012, if that makes any sense.
          Never found any patterns or answer to it. I have not checked, maybe service pack 1 helps?
