Select Model Elements node
    when i try to select multiple elements in Revit, it seems only allow (crossing) window selection mode, no CTRL or SHIFT selection, no filtering, is it normal? i know i must miss something simple here
    It does appear that only drag-selection is able to be done.
    You can work around this by going into a 3D view and hiding off everything you don't want to select... annoying I know but the only solution I can think of.
    Sol Amour
      really?! i didn't expect Dynamo's UI is that bad, well, another case is that i cannot "Create Similar" from existing node (again, did i miss something simple here?), so i have to go through browser to pick right node again and again.
      thanks amoursol for your conformation!
      edit: OK, seems CtrlC+CtrlV will do the trick even though no (context) menu is available (?)
        Standard commands do work as you have highlighted and the feature density upon each new stable release is pretty robust.
        If you want to see a feature - you can propose it to the developers on github:
        https://github.com/DynamoDS/Dynamo/issues
        Simply prefix your request with 'Wish - ' or 'Feature Enhancement - ' or somesuch. The dynamo team will assign people to it or put it on the to-do list if they think it important enough.
        Sol Amour
          thanks amoursol for the suggestion, in fact, Dynamo's UI isn't bad at all, searching node by typing related text is wonderful!
            If using build 0.8.1 onwards you can search in the canvas space as well with Shift + Doubleclick and RightClick in the context menu.
            Sol Amour
              good to know, thanks amoursol, well, this Dynamo reminds me of my very first visual programming experience long time ago which is LabView, mainly for engineerning stuff.
                Good experience or bad ?
                Sol Amour
                  good for people w/o or w/ limited programming experience, not so good for experienced programmer.
                  but i think Dynamo is very good for simple tasks or build quick test prototype for further NET based API development.
                  • Selection in Revit to Dynamo?
                    I've been doing some basic scripts to ease my workload and I've often wondered if it possible, to use the selected objects in Revit as if it was selected...
                    December 13, 2016, 01:27 PM
                  • Picking multiple elements
                    I'm looking for a node that will allow me to pick multiple elements. I know that the OOTB node "Select Model Elements" will...
                    January 2, 2021, 12:39 AM
                  • GetSurroundingElements Node Not Working
                    Anyone have any ideas on why the get surrounding elements node would be failing me here in the attached script image? I know it use to work and it works...
                    October 25, 2016, 08:23 PM
                  • Create a selection set
                    I'm testing out some code to create a Revit Saved Selection set which I'm going to use in another routine. I'm using the Clockwork package...
                    December 2, 2015, 01:00 PM
                  • Spring Package Interference Check node does not work
                    hey all ,
                    the node in the spring package does not work in revit 2020
                    does anyone has any idea why it is not working?
                    and...
                    June 13, 2019, 06:58 AM
