is there a way to hide a certain wall type in all views in a project?
Hide wall type in all views?
This topic is closed.
You need to create a filter, and then include that filter in template views. Then, apply that template view to your views.
For example: you don´t want to see a wall named "Generic 10 inches". Then you go to VG > Filters, and add a new filter called "No generic 10 inches", which you apply to Walls, by Type Name > equals > "Generic 10 inches". Once the filter is created, you can go to View Templates, V/G Overrides, and apply this particular filter, with visibility OFF, to your templates. Then, re-apply templates to views.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Alfredo Medina View PostYou need to create a filter, and then include that filter in template views. Then, apply that template views to your views.
For example: you don´t want to see a wall named "Generic 10 inches". Then you go to VG > Filters, and add a new filter called "No generic 10 inches", which you apply to Walls, by Type name equals "Generic 10 inches". Once the filter is created, you can go to View Templates, V/G Overrides, and apply this particular filter, with visibilty OFF, to your templates. Then, re-apply templates to views.I'm retired, if you don't like it, go around!
I'd say this IS the magical easy button... Remember that you can save your filter in your Project Template (which would be handy if you have to use it across multiple projects).Martijn de Riet
Applies to: - All Verticals
New Feature / Problem:
Right now you have to setup what the filter is selecting and you then apply it...-
Channel: Wish Lists / Feature Requests
February 3, 2016, 04:48 PM -
I have some view filters where I have set display overrides for Projection and Cut values. These filters are for checking purposes rather than for printing....September 9, 2014, 11:26 PM
What steps would I have to take to apply a filter that makes building sections invisible but other sections still showing? I know I would have to go in...March 20, 2018, 07:15 PM
I have (2) different section types in my file for two 2 different permit submissions. One is called "CDP Section" and one is "CD Section"....October 20, 2020, 09:26 PM
Hi everyone,
Wanted to get some opinions on how people go about filtering unreferenced views. We like to do this to clean up our "Published"...September 11, 2013, 06:00 PM
