Hello! I've created a truss family for a roof structure. Can someone tell me how to assign specific cross sections to different members of my truss?....Right now,all my members in the truss have the same c-s. (I assume this is a dumb question...Sry,i'm new)
Assigning different c-s to truss members ?
The top cord, bottom cord, vertical webs, and horiz webs can be assigned from the type properties window after the truss is placed in your project. You will need to load the member sizes and types first. The truss family is just a template. No member association is assigned within the family.
http://screencast.com/t/ZSWk7IEL
Hope this helps.-Alex Cunningham
When you place a truss family, it will make all of the members in the truss the same size as the LAST framing element you placed.
If you just placed 600x600 concrete beams, your truss will be that.
If you just placed 25 x 25 Equal Angles, your truss will all be that.
What I usually do is place a member in the size of my desired top & btm truss chords, then quickly delete it just so I get the member I want.
Then click on your newly placed truss and do as suggested already, in the properties of that truss you can set the other members.
But you can not set other webs ie you can not have one web in the same truss different to another web of the same truss (hope that makes sense) All webs are the same is what I mean..within the one truss.
Originally posted by lucis29 View PostAlex, just a small advice.
Revit is not ready for steel detailing. I recommend you use other programs.-Alex Cunningham
Well, I don't do detailling a whole lot, but when I do, most of it is in 3D too... sssoooo pretty...Martijn de Riet
This is completely untrue. I detail steel in revit often, get great results, and furthermore can provide 3d views of difficult connections for clarification on my drawings. Trying to keep on track, these are steel truss custom made families, AND modelled steel bracing cleats and fully modelled joints which I used on a project to show a complex connection.Attached FilesLast edited by Karalon10; August 3, 2011, 04:27 AM.
Originally posted by Alex Cunningham View PostThe top cord, bottom cord, vertical webs, and horiz webs can be assigned from the type properties window after the truss is placed in your project. You will need to load the member sizes and types first. The truss family is just a template. No member association is assigned within the family.
Hope this helps.
But you are still limited to only having settings for "Top Chord, Bottom Chord, Verticals & Diagonals"
If you need particular Verticals or diagonals you need to reassign after creating the truss in the project
The problem with trusses is that you cannot easily create a fully welded truss that looks good in 3D, you are left with manually coping each member.
We need an option to specify the end join which will automatically cope each truss member if specified
Karalon, you left the reference to a particular company in the disclaimer
Hi everyone:
I would like to customize a big size of truss system length 66000 mm, height 3000 mm to the convention center project. However,...-
Channel: Structure - Family Creation
February 2, 2015, 08:58 AM -
I'm working on a truss roof and I've two problems with my Truss family.
1) My truss members are assigned as follows (the first image shows the settings...-
April 12, 2016, 01:05 PM -
Hello All
I am looking for some revit 2018 families for the following situation as I am working on a project that requires a Single sloped...-
October 5, 2019, 06:32 PM -
Hello All,
I have a project that is using a scissor truss and the tech who created the project just used an OTF truss family. the arch wants...-
August 2, 2018, 05:11 PM -
