Hello, I am trying to draw plans for my garage addition and need help illustrating rebar in concrete footings, floor slab, and walls. I am using Revit Architecture 2014 but I do not see the Rebar tools in the Structure menu. I just want basic rebar to get my garage passed and I have been trying for a while but getting no where. My revit project is about 7mb large and I can e-mail to you. Thanks Kevin
Need help with drawing rebar for garage addition wall footings and floor slab
Welcome to the forum.
Make a section view. Then, in the section, click on an object that can host rebar, such as a footing. The rebar icon should appear on the ribbon. Click on the icon and you will see the rebar tools.Attached FilesFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
That's true. And that was written there, in the original post. Thank you for the correction.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by stl4310 View PostLooks like it's detail line time!Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
How to create a rebar family in revit structure
Channel: Structure - Family Creation
October 8, 2014, 12:38 PM -
Dear All,
While I use the command "Place rebar perpendicular to work plane" and put a rebar in a slab and then specify the maximum...-
April 12, 2011, 09:20 AM -
Hello All
This is the first time I have run into this error.
I have a concrete slab and have modelled it with the area reinf...-
September 10, 2013, 01:05 PM -
I modeled floor slabs, from there I went to section views and placed Rebar in them. I had to make some changes and add more Rebar after that. I see that...
January 19, 2012, 05:46 PM -
Hi All,
I have been doing some rebar detailing over the past few weeks in revit 2016, so I am still very much amateur. I Find it very user...-
February 22, 2017, 06:57 AM -
