Is anyone very familiar with the concrete reinforcement Revit extension?
REX Rebar
I can't say that I'm very familiar, but I tried every extension, with or without success.
I don't have enough time to get deeper for now, but I would be glad to speak with someone testing features like I did.
Those extensions seems to me "unachieved" or at least partially. And help is not easy to find.
I hope I will work also with ASD extensions, and Robot extensions at the very beginning of 2011.
See you in 2011.Julien
P. DAC
I only use Revit for concrete. I do believe it doesn't stand any chance in front of Tekla, or even ASD steel.
I'm having problems with the one that sends reinforcement or formwork into ASD.
I mean that I've done the model in Revit Structure, but this is useful just for slab formwork. I need to send the beams into ASD for reinforcement, but the Extensions doesn't work.
I have Win 7 x64.Revit Architecture 2013 Certified Professional
Well since I have numerous replies I will try with the questions.
Is there any way to give a maximum bar length? I am doing many floors, beams, etc and the they are over 40' so when it places my bars it does 40'+ bars and we have a 40' bar max.
We have been doing the detailing by in Revit (no macro or extensions) so we use the standard bar shapes 00, 17, 17A, S1, etc...is there a way to have the extensions use those shapes rather than using oddly named ones as it does for me right now?
Thanks,
Grant
Hi all,
I did some tests thinking about this post:
- reinf. extension for beam doesn't work for me, even with the original beam family
- same thing for in-place beams
any idea?Julien
P. DAC
Got it, beams works fine now:
the family must have the parameter "Shared" check. So simple.
In-place beam don't have such parameter, so it doesn't work.Julien
P. DAC
I have:
RST 2011 + Extensions
ASD 2011
When I try to export to ASD (Formwork or Reinforcement), nothing happens....-
December 20, 2010, 07:46 AM -
Hello All
I was just wondering if anyone know if there is or knows how I can set the vertical rebar in the extensions to be on the outside...-
November 28, 2012, 07:39 PM -
Would someone please explain the use of extensions. buffer's ?
Thanks...January 18, 2013, 02:57 PM -
I had this add on for RAC 2011. Is there one for RAC 2012? If there is I can't find it on the Subscription site. Or, maybe the 2011 version will work...May 27, 2011, 10:12 PM
Hi!
Got a slight irritating problem with the extensions tab. On every start up the tab moves as far to the left as it goes.
And on...-
Channel: Third party Add-Ins, API and R&D
September 2, 2011, 05:17 AM -
