I've been tasked with Revitizing a room Matrix schedule for our interiors group. I've attached a jpg of what its supposed to look like, but for the life of me, I can't seem to get it to work inside Revit beyond linking in Excel... Anyone else have one of these?Room Matrix schedule.JPG:banghead:
Creating a Room Matrix Schedule
Originally posted by Rushdog View Post...what its supposed to look like... [ATTACH=CONFIG]22327[/ATTACH]:banghead:Last edited by JBZ; June 12, 2015, 08:11 PM.
Hey Jay, Well what they want to do is schedule all the room types for hotels. In the one above the rows are rooms per level, and the columns are the various room types, (k1 for king size, JS for junior suite, etc. etc.) The Schedule I've attached is from Excel, and is manually input, then linked back into Revit. What they want is for Revit to pull the info and populate the schedule automatically, the reson being counting your own rooms is bound to create some errors. Now we can certainly make a schedule for each room type, but where the room doesn't show up on a level, the level "Row" wont show up. So in the context of the matrix I've tried approaching it by creating the individual schedules for each room type and hiding every parameter but the count. Problem is for some I'll get 8 rows and others I'll get 1 row and everything else inbetween. Question, can you schedule or have a NA value for a room that doesn't show up on a floor? and can you do this in one schedule as opposed to one for every room type?Last edited by Rushdog; June 12, 2015, 09:27 PM.
Originally posted by Rushdog View PostNow we can certainly make a schedule for each room type, but where the room doesn't show up on a level, the level "Row" wont show up... Problem is for some I'll get 8 rows and others I'll get 1 row and everything else in between. Question, can you schedule or have a NA value for a room that doesn't show up on a floor? and can you do this in one schedule as opposed to one for every room type?
1) Room Types??? Is that an added shared parameter? -Sorry, I am in a Revit 2014 project at the moment, so I cannot check 2016, since that's at home
2) Rooms not on a level??? How is that??? I cannot duplicate the issue of a room not being on a level...unless it is simply not placed in the model
3) When you write "for some I'll get 8 rows and others I'll get 1 row and everything else in between" Some what...Levels???
I've not seen rooms schedule improperly as you seem to be finding (outside of the Room Type that I do not understand, since that is not a hard-coded Revit Parameter or option), Do you have filters, unplaced rooms, or phases or design options getting in the way perhaps?
The issue with the format you've shared is the horizontal organization of the data. Revit doesn't organize data across like that. You can definitely summarize rooms and rooms types and list them by floor in a Revit schedule but as you've noted it isn't in the familiar format that you want.
Revit schedules are very much like a query of a database (if you've ever used Microsoft Access for example) combined with basic reporting functions. In MS Access we build tables, then queries, then reports based on the results of the queries or even a combination of them. A query is just asking Revit a question and the schedule's reporting side is the answer. In MS Access we can ask a new question based on the previous answer, a query of a query...and then create a report based on that answer. Revit is not so flexible.
In Revit schedules, when you select a category and the parameters to appear in the schedule you're telling Revit what table of data to look in and then what unique data in those tables are relevant to you. The sorting/grouping defines how it should organize the data to be more meaningful. Sorting a database query with specific criteria creates a conflict when some of the data doesn't include anything meaningful for that value. For example, a room or room type that is not present on a specific floor won't have a unique row to say "Sorry there are zero rooms of this type on Level 3", it only reports rooms and room types that EXIST.
Likewise, Revit won't show N/A in data fields, unless N/A is THE text value that we've typed into a parameter. It either shows the information that is present in the record or it doesn't. For some parameters Revit is more wordy, like when a room is redundant or not placed yet.
If you can live with a vertical summary of the information then you can tell the story you need to tell, just written differently, with a different author's style than the last story you told your client.
If you're looking for an automatic way to get exactly what you want in the image you can consider a couple applications, available now, that will let you extract the data, export it to Excel and then reorganize it into the desired format, then import it back into Revit.
IDEATE Sticky ($395 stand alone)
CTC Schedule XL (included as part of their BIM Project Suite - $450)
They both take advantage of the relatively new API (a couple years old now) access to customizing the header portion of a schedule. The live data is extracted and then reassembled into the header portion of the schedule using the format of the external Excel file you reorganize it with. You could do the same thing manually within a schedule's header, but that's a bit more labor intensive and it won't update without repeating the process each time the summary changes.
Room types as in it would have to be an added shared parameter to make a column in a schedule. at least I'm assuming, (I know don't assume) that you would have to make a parameter, as I can't make the room name parameter into schedule columns.
2. When I say rooms not on a level, I mean that in the context of a schedule that is taking into account all Rooms from All Levels, O want my schedule to have all a levels showing in the Rows, I.e. 1st 2nd 3rd 4th... the in the columns each room would show how many it has per level. Now lets say room2 is on levels 1 & 2 & 4, in the schedule there should be a 0 for the 3rd level, since room 2 isnt there. (I'll bring this to the RUG meeting on Weds...)
Originally posted by snowywestonAfter you've input all your rooms' with your custom shared parameter information you could make that matrix with a Pivot Table in Excel in less than 5 minutes. No need for any expensive addins.
Originally posted by Steve_Stafford View PostIf leaving it in Excel format is acceptable
1. The deliverable is a .pdf - so how you get there doesn't matter
2. The recipient, if requiring the data to juggle, will be more comfortable working with an .xls over an .rvt
Originally posted by Steve_Stafford View PostThe price point for the software does help define how serious someone is.
*if not, then yes, I've missed your point.
I'm experimenting with an Embedded Schedule to list the equipment in each room.
I've got a Room Schedule that pulls the Room Number, Name, and...February 28, 2018, 01:42 PM -
How are others dealing with signage (room, general, etc.)?
I knee-jerked to creating families and schedules that pull information from...March 11, 2014, 09:01 PM -
Is there a way to schedule valves per room ? Having a schedule showing all the valves
within in a room-
Channel: MEP - General
March 9, 2018, 05:53 PM -
I wanted to know if there was a way to search for rooms through the room schedule. For example you can schedule equipment and search it through the schedule....November 6, 2014, 02:46 PM
So, has Revit managed to make it so you can make an "alternate" Room Schedule? Or should I just make it text?
Just wondering.
Thanks!...May 4, 2017, 05:24 PM
