Fixture units not reading on all items
    I have got my fixture units set for my waste/sanitary connector on my sinks, why I inspect the system the units are reading on some sink but not others even though it is the same family/sink with the same units it is just reading 0
    any ideas?
    • Are the pipes really connected? Sometimes they seem to be connected, but they're not.
    • Does any of the fixtures have a connector that is not capped? If you have a chain of fixtures connected, but one of them has one open connector, the system will not report fixture units on the pipes, or at least on the pipes that are connected to the fixture that has one open connector.
    • Does the plumbing fixture family have connectors set to report fixture units?
    • Plumbing family - Fixture Units
      Someone in my company created plumbing fixture families, but they don't translate the fixture units to the piping. I added them as an instance parameter,...
      May 9, 2016, 01:03 PM
    • Plumbing Fixture units
      Could anyone help, im trying to add waste demand units to a plumbing fixture by a shared paremeter.. but in the family the waste connector is greyed out...
      October 15, 2014, 09:55 AM
    • Fixture Units Below 1?
      When I set my fixture units to 1 the corresponding l/s is 0.189. However When I go to 0.5/0.250.001 fixture units this value remains the same? Obviously...
      March 14, 2016, 12:33 PM
    • Cap Family to Generate Fixture Units
      I'm trying to create a cap family that can generate fixture units for flow tracking in our projects. My intended workflow is:
      Draw pipe to connection...
      May 16, 2018, 10:40 PM
    • Calculating fixture units through T's
      Hello all,
      My firm uses Revit as a drawing software, we draw pipes in it and coordinate them but haven't used the software to it's potential;...
      April 15, 2021, 03:32 PM
