Exporting / Importing Search Sets
    Hi all,
    i have a set of search sets i would like to use in another file so i have exported them.
    When i try to import the search sets, nothing happens, they are not added tot he file.
    As far as i can tell, i am doing it correctly, it is a simple case of using the export button on the set dialogue box, isn't it? Is there some hidden trick to this?
    Andrew Harp
    BIM Manager GHD
    Are both files in the same version of Navisworks?
    Mason Blalack | Navisworks Guy | Beck Group
      Yep, both 2015 Manage.
      Andrew Harp
      BIM Manager GHD
        Are you sure the sets you made are Search Sets? The export tool will only export Search Sets not Selection Sets.
        Search Sets have a little binocular next to them and selection have a blue square with a circle.
          Yep, definitely search sets.
          I tried with a new file and that seemed to work. Maybe a file error.
          Andrew Harp
          BIM Manager GHD
