I'm trying to create an extruded "fin" to put into a Curtain Panel Pattern Based family. I'd like to be able to control the depth and width of this fin with parameters.
my method was to create a point on a line, draw a rectangle on that point's reference plane, select the profile and the line and create a form, which works fine.
the problem arises when i try to modify the dimensions of the profile. it only modifies the profile that sits on that point, and not the ones on the end.
I guess my question is do i need to apply the parameter to three places to get a box extrusion (beginnning, end and point on line)?
