Using Curtain Wall for Piles walls
    I recently did a job that required a large amount of piled walls. I used a line based family with one nested pile.
    This worked ok but I need more flexibility to adjust the top and of the pile wall.
    If I have a similar job again I think I might try to use a Curtain wall with Mullions set to circular Mullions. The disadvantage will be if you adjust for example the top of the wall the pile (mullion) will not be horizontal - it will follow the angle of the wall.
    J
    Originally posted by jh75 View Post
    ... The disadvantage will be if you adjust for example the top of the wall the pile (mullion) will not be horizontal - it will follow the angle of the wall.
    But in the file you provided, the top of the mullions (piles) is horizontal, it does not follow the angle of the wall.
      Hmm you are correct - don't know how I missed that. My only excuse is that I posted that before my morning coffee and didn't have my glasses on
      That is how I wanted it ie the pile top to be horiz.
      J
        No problem, then. Enjoy your :coffee: and happy 4th of July.
          As an architect, I would hate to have piling created as mullions, but can see your reasoning for doing so.
          I'm currently working on a project where mullions are used for piling by Structural. A real pain as a) I have to clean them out in the linked filed in views and b) you won't be able to schedule them properly.
          For my next project, I will absolutely refuse for this method to be used again.
            You could get crazy with your line based family and make them adjustable. I am thinking Instance based length parameter for the nested family. Maybe my coffee hasnt kicked in... i do feel crazy this morning.
            -Alex Cunningham
              Why not use a Beam System? It has all the advantages you just stated, but is in the "right" category...)
                I did a post way back in the day on the old Augi forum, regarding the same question.
                The answer was, essentially, that it cant be done.
                I think the best way to do it, is to array piles at the desired centres, use a standard concrete wall, and make them the same material so that they 'blend' at the intersection of wall and pile.
                Next problem: Rock anchors.
                There is a huge demand for some kind of family or add-on that could set out your piles at correct spacings, AND allow you to insert and declinate rock anchors (and then to have them schedule, AND have a nice symbol for the elevation) so if anyone knows how to program or nest those kinds of things, you would be a squillionaire.
                  I have created a Rock Anchor but it is very much a WIP. You can schedule bond length, lock of load etc.
                  J
                    I must be missing something here, see attached...
                    I used a round steel beam (cause I couldn't find a concrete one just now), but this can do what the OP stated. You can have all sorts of top forms, just made one with a curvy top.
                    Only thing it doesn't do is join the beams, but that might be the type of beam I used.
                    Create the Beam System in Plan, then rotate in Elevation. You can modify after rotating it.
